Nautique 2009 196
  • btmacveagh
    • Sep 2017
    • 3
    • Davis, California
    • 2009 196 Limited Nautique Excalibur 343 engine
    Nautique 2009 196
    If I want to change the impeller, how do I loosen the belt? Is there ad idler pulley? Where? If I turn a pulley backwards to loosen it, which pulley? Help!
  • Nautiquehunter
    • Jun 2008
    • 2080
    Should have a spring loaded tensioner. My 08 5.7 uses a 5/8 wrench to unload the tensioner.
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      OK, this isn't difficult. First thing: Look at the various pulleys and identify them. Alternator, Raw Water pump, main crank, circulation pump. Then there will be one that's off to the side and it'll have a big hex fitting sticking out, right in the middle of the pulley. This is the belt tensioner. Find the right wrench and pull on it. It should be spring-loaded. Pull it back far enough to get enough slack so the belt will slide off one of the other pulleys.
      -Charles
