confused here...
  • Bobby
    • Jul 2004
    • 87
    • Norman, OK
    confused here...
    why is it that an old '82 Ski Nautique with a carburated 351 pulls so much harder and has a higher top speed than the newer '96 Sport Nautique with the GT-40 EFI motor rated at 310hp? My 96 Sport tops out at around 38mph, has a 4 blade prop - and it doesnt pull near as hard as my parents' 82 SN, which also has a 4 blade prop. I wouldn't think that the different weights of the boats would be too far off to make that big of a difference, but I could be wrong. Anyone know what's up? :?: :???:
    1996 Sport Nautique w/ EFI GT-40
  • surroundsound64
    • Jul 2005
    • 2147
    • Longview, TX
    • 2018 230 1981 Ski Nautique
    My first guess would be the prop. Then I would ask what is wrong with the 96. Then I would ask if the 82 has been modified.
    Cool to have another Oklahoma guy here! I'm from Duncan, I moved to Tx this past August.
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    • M3Fan
      • 1034
      Less surface area on the old boats, less drag. Still to slow for the 96 though. What's the RPM at 38MPH? The RPM on the 96 at WOT will help us figure out the problem.
      2000 Ski Nautique GT-40
      2016 SN 200 H5
      www.Fifteenoff.com
      • Bobby
        • Jul 2004
        • 87
        • Norman, OK
        ill check next time i go out. i'll also give it a tune up to see if it helps any.
        • BigBald
          • Jan 2004
          • 529
          • Indianapolis (Carmel), IN
          Are you running side by side and comparing? Could the speedometer be off in one of them? As far as pull....I would guess it's the prop. I know that the new prop in my 99 Sport made a big difference in the pull.
          88 Ski Nautique
          99 Sport Nautique
          • bkhallpass
            • 1407
            • Discovery Bay, CA
            350 lbs. difference in those boats, which is significant. However, you should still get at least 43 and probably 45 from that sport. As said, prop or tune up are likely issues. BKH
            2001 Super Air
            • 82tique
              • Aug 2004
              • 156
              • Butterville, Land-O-Lakes
              it's simple.....the '82 is the most bad *** nauti' ever made :grin:
              Life is Good.
              • Rick
                • Mar 2004
                • 1250
                • San Diego, Ca
                The number of baldes the prop has doesn't matter, the pitch does. I would bet that the older boats prop is 1/2 inch bigger in diameter and 2" pitch less. The 96 is probably running a 12.5 X 15.5 and the 82 is probably running a 13X13 Check it out Good Luck
                Nautiqueless in San Diego
                • Bobby
                  • Jul 2004
                  • 87
                  • Norman, OK
                  it reads 4200 rpm at 38mph.
                  • 83sn2001
                    • Mar 2005
                    • 151
                    • belmont, nc
                    I believe WOT RPM on a GT-40 is around 4800. You may want to try a tune up and change the fuel filter for starters. My 83 pulls strong but it is no GT-40 even considering the bigger boat.
                    • dave210
                      • Jan 2006
                      • 113
                      • jax fl
                      something is wrong with the sport top end will be close with the 82 but the gt 40 should pul hard out of the hole
                      • Roy
                        • Jun 2005
                        • 28
                        I think you have the wrong prop, contact Acme or CC customer service, the GT-40 should see 4800 rpms, you are luging the engine.
                        Happy Boating!
                          • 2908
                          Roy,
                          My initial reaction was the same but read on, he is only going 38mph so it's definately not overpropped. Something is not right with the motor.
                          • Bobby
                            • Jul 2004
                            • 87
                            • Norman, OK
                            the prop on the sport is a 13 x 16. Also- there is a distinct gas smell from under the teak platform when it idles.
                            the '82 has a 13 x 13 prop and the dang thing will almost pull your arms off. I think it might just be a freak.
                            • Rick
                              • Mar 2004
                              • 1250
                              • San Diego, Ca
                              I'll bet with a 13X13 your 96 would top out at 4800 RPM and pull as hard as the 82 I have a 12.5X15.5 on my 2000SN with the MPI GT-40 and I'll bet I could pull 6 skiers up at once.
