PCM EX343 winterizing help please
  • HutchCanada
    • Oct 2014
    • 61
    • Markham, Ontario
    • 2010 Super Air Nautique 210
    So getting read to winterize my '10 210, first time. Pretty sure I have it order but wanted clarification on a few things from anyone who's done it before.
    After draining the block, manual says to pour AF directly into thermostat housing instead of sucking it through raw water intake. Is this it?
    Are these the lines to the heater?
    Transmission cooler?
    V-drive drain plug?
    FCC drain plug?
    Thanks. I don't want to screw this up!
    Sent from my SM-G930W8 using Tapatalk
  • Quinner
    • Apr 2004
    • 2245
    • Unknown
    • Correct Crafts
    My personal preference is to drain everything and then suck up the anti-freeze, it takes about 5-6 gallons instead of 2 but cheap insurance IMO to ensure there is no water left anywhere throughout.
    Not sure about the VDrain plug but all your other plug/line locations are correct.
    • Evening Shade
      • Apr 2015
      • 1295
      It looks like you have everything correct, but don't forget to pour the water out of the strainer otherwise it will freeze and crack.
      I have never used antifreeze with my boats. I just drain the water. The antifreeze seemed like a great idea, but it was always so hard to get to the intake hose that I decided it wasn't worth the hassle and I've never had any problems. Plus, how do you know if your thermostat is opened when you run the antifreeze through? If the thermostat is closed it will just circulate through the exhaust manifolds and out the exhaust and won't circulate through the block.
      • HutchCanada
        • Oct 2014
        • 61
        • Markham, Ontario
        I think getting the boat up to operational temp should ensure the thermostat is open?
        • charlesml3
          • Jan 2008
          • 2453
          • Lake Gaston, NC
          • 2022 G23
          Yes. This exactly. Ideally, you should add Stabil to the tank first. That way, as you're warming up the engine to open the thermostat, the stabilized fuel will circulate through the entire fuel delivery system.
          -Charles
          • Quinner
            • Apr 2004
            • 2245
            • Unknown
            • Correct Crafts
            No, bad info above on the T-Stat.
            T-Stat position does not matter as long as a drain is done first as it always should be. TStat blocks the exit not the entrance.
            Shade is correct however a drain only "should" be fine, for me adding the a/f is a gaurantee that any residual water is flushed out/mixed with the a/f, perhaps a little corrosion protection as well.
            • HutchCanada
              • Oct 2014
              • 61
              • Markham, Ontario
              Do I have the right hoses for the heater? Blow air through them and then AF?
              • Quinner
                • Apr 2004
                • 2245
                • Unknown
                • Correct Crafts
                Yes, red hoses are going to/from the heater core. Just pull the top hose at the intake manifold, with the drain plug removed at the J-Tube, blow the water thru the hose and it will drain from the J=Tube drain. Backfill is up to you, if you do a suck up then they will be backfilled.
                • HutchCanada
                  • Oct 2014
                  • 61
                  • Markham, Ontario
                  Is #23 the J tube?
                  • Quinner
                    • Apr 2004
                    • 2245
                    • Unknown
                    • Correct Crafts
                    Yes and 27 is the drain plug
                    • HutchCanada
                      • Oct 2014
                      • 61
                      • Markham, Ontario
                      Ok great. Thanks this really helps me a lot.
                      • Evening Shade
                        • Apr 2015
                        • 1295
                        I stand corrected on the T stat, but I do have a couple questions.
                        How are you guys getting your boats up to operating temp? I have a Fake-a-Lake, but it won't fit flush against the hull of my boat because the brass water intake grate is too big. I did try to run the engine very briefly with the FaL and water came out of the shaft seal, but I was concerned about water getting to the engine because no water was coming out of the exhaust. I shut the engine off after a few seconds because I was afraid of harming the engine or shredding the impeller.
                        How are you guys sucking the antifreeze into the engine? The water intake hose so too short and rigid to pull up out of the bilge to put it in a 5 gallon bucket.
                        • HutchCanada
                          • Oct 2014
                          • 61
                          • Markham, Ontario
                          Newb here. For warming boat up I plan on using a longer hose connected to raw water intake. Other end in large bucket of water with a constant water supply from garden hose. I might also trying rigging up something to attach the garden hose direct to water intake. For AF put your DIY longer hose in AF. I saw this done on a DD and it worked just fine
                          • HutchCanada
                            • Oct 2014
                            • 61
                            • Markham, Ontario
                            Connect here
                            • charlesml3
                              • Jan 2008
                              • 2453
                              • Lake Gaston, NC
                              • 2022 G23
                              Hutch has it right. Connect a garden hose where he indicated. This will supply PLENTY of water to get the engine up to temp. While it's doing that, get a 5-gallon bucket ready with AV antifreeze. Shut everything down, and put a short hose in the bucket and restart the engine. It'll draw all the antifreeze out, up and around the engine. As soon as the bucket is empty, shut down the engine and you're winterized.
                              -Charles
