Winterization walk-thru of the PCM 343EX 5.7L raw water cooled engine. Boat is a 2010 SAN 210. Heater and ballast system. I live in Toronto and it gets waaaay below freezing here so I go overkill. I hope this step-by-step will be helpful. Much of the info here I gathered from PN. Thanks to all who helped me.
Step 1:
Fill up gas tank and add fuel stablizer. Run the boat for 10-15 minutes. I did this out of the water using a garbage can full of water, sump pump hose and constant water supply from garden hose. Connected the sump pump hose with a 1 1/4 barbed PVC fitting to the hose coming out of the raw water filter on the downstream side
Other end of sump hose went into garbage can already filled with water. Weigh it down so it stays on the bottom. Garden hose on full blast into garbage can. Start will the garbage can 101% full. If you have low water pressure at your house it might not be able to keep up, mine barely did. This method imo far better than a fake-a-lake.
Run the boat making sure water coming out of the flapper. 10 minutes. Operating temp 160 degrees F.
Step 2: change oil and filter.
Step 3: Remove large plugs on each exhaust manifold
Step 3: remove knock sensor plugs from block
Starboard side
Port side
Step 4: remove inlet hose from tranny cooler. This is on the starboard side. Manual says to take out the plug which is virtually inaccessible. Just pull the hose off
Step 5: remove plug on J-tube. Port side at back. Plug removed in pic already
Step 6: remove V-drive plug. This one you're pretty much blind. On my boat I only needed a 1/2 drive, no socket.
Plug is under the grey/rusty part
Step 6: remove heater hoses. These are orange. Take them off and blow in them. Water will come out J-tube. I tried compressed air but blowing with my mouth worked way better. I was surprised how much water came out the J-tube drain hole.
Top heater hose
Blow in here.
Bottom heater hose. Harder to get to.
Apparently the bottom heater hose is not necessary.
Step 7: Put all plugs back in. Don't put any thread coat or tape on the knock sensor plugs. Torque to 16 ft.lbs. and reconnect wires. The other plugs just snug them down.
Step 8: winterize heater. Since I had the heater hoses off, I poured AF down them till it overflowed. Then I reconnected the hoses. Local marina used to charge me $100 for this step alone.
Step 9: run AF through the engine. I did this by simply putting 5 or 6 gallons of AF in the garbage can and sucking it up with the motor running just as in Step 1. Watch the AF level it goes down wicked fast. When AF coming out exhaust flapper shut the engine down. Note this step is not prescribed in the PCM manual but I did it anyway as pretty much everyone recommended this.
Step 10: Pour AF first into hoses going from T-stat housing to exhaust manifolds.
There are 4 hose ports on the housing. Top 2 go to manifolds. Remove those and pour AF in.
At this point in time the engine is empty of water and full of AF.
Step 11: drain FCC
7/16 plug on bottom of canister. About a pint of gas will come out so have a small container ready.
Step 13: remove serpentine belt and raw water impeller. Clearly described in manual. If impeller still good, store in a zip loc bag indoors along with your belt.
Step 14: fog the engine. Remove the spark plugs. Spray fogging oil into each cylinder for 5 sec. Crank motor over a few rotations to starboard using a 5/8 socket on the crank shaft at the rear of the boat. Replace spark plugs. Mine had 400 hours on them so I replaced them. AC Delco 41-993. Gap 0.060. Torque to 20 ft.lbs.
Step 15: run AF into ballast system. Another $100 my marina charged me to do this simple step. Pour AF (about a gallon for each rear tank and about 2 gallons for belly) into each of the 3 ballast vents. Run ballast pumps in reverse till you see AF coming out under boat. I had sacs piggybacked on top of the stock tanks so I had to pour the AF directly through the vent hoses coming off the hard tanks.
Sorry no pics but this step is really easy. I removed my fat sacs. Not necessary but lets them and the floor finally dry out.
Remove ballast impellers and store indoors or replace in spring.
Step 16: empty and clean raw water strainer if you haven't.
Other items you might wanna do now or in the spring:
New FCC element and inline fuel filter
Lube throttle and shifter
Change trans oil
Clean flame arrestor
I hope this helps all that have the PCM 343. If I missed anything please let me know!
HutchCanada
Sent from my SM-G930W8 using Tapatalk
Step 1:
Starboard side
Port side
Top heater hose
Blow in here.
Step 11: drain FCC
Change trans oil
HutchCanada
