GT40 HEATER CONNECTIONS
  • tommyb
    • 27
    • UK
    HAS ANYBODY GOT A PICTURE OF WHERE TO CONNECT THE HEATER PIPES ON A GT40? 02 SAN
    THE WALTHROUGH INSTALL POST IS GREAT BUT NOT MY MOTOR
    ANY HELP PLEASE.
  • jhiestand
    • 778
    • Columbus, Ohio
    • 08 Super Air 210
    I don't have any pix here on my work machine but connections for your motor are at the top where the thermostat is and the bottom of the engine where one of the block drains is located. To make the job simple, you need a 45degree fitting to clear the fuel injection rails. Check out the below thread.
    http://www.planetnautique.com/index....ht=heater+gt40
    If you still have problems, I can prolly score some pix at home.
    '08 Super Air Nautique 210
    • richard
      • Feb 2005
      • 406
      • HK
      GT-40 Heater connection
      The pic shows one ocnnection of the heater hose,unfortune don't have other side.
      • wake_fun
        • 1330
        • CA
        • 1995 Super Sport
        RE: GT-40 Heater connection
        Look in my gallery
        Photo Album
        Ballast Install 1
        Ballast Install 2
        Amp Install
        PPass Install
        Alternator Install
        • AirJeff
          • Jul 2004
          • 168
          • White Bear Lake, MN
          What would happen if you hooked up one hose to the elbow on the engine water pump?(not raw water) Would that fix the low speed heat issue? And then where would you plug the other hose into? I know I can get the low speed fix, just wondering if it's really needed.
          Jeff
          2002 Air Nautique (DD)
          GT-40
