Oil Filter Cross Reference
  • jslipher
    • Jul 2013
    • 76
    • Midwest
    Is there a cross reference oil filter to the one recommended in the manual? Part # recommended is R077001
    Also, does everyone change the fuel filter as part of winterization process?
  • functionoverfashion
    • Jun 2017
    • 511
    • New Hampshire
    • 2003 SANTE
    I believe the R077001 crosses to Napa 1515, Motorcraft FL1A, Mercruiser 35-802886T, Fram PH8A and some others. I used to use the Mercruiser part when I worked at a marina, they were on the shelf. Or Napa 1515, because you could get one the same day more easily around where I live.
    • AdamJBarn
      • Feb 2016
      • 51
      • Fishers, IN
      • 2002 Super Air Nautique 210
      Wixfilters.com; and yes, change your dang fuel filter!
      • toomuchuv
        • Mar 2013
        • 190
        • Canada
        • 2014 SAN 230
        Don't use fram! Lots of sites say they are junk. Go with the FL1A. Cheap at Walmart and a very good filter!
        Sent from my SM-A520W using PLT Nautique mobile app
        "I'm on a boat........"
        • Ossie
          • Dec 2019
          • 1
          • Melbourne
          • Sport 200
          So did some Xref check on the KnN filter website and found the Ford 173231 and GM 9002514 specified OEM part numbers are also shown for the R077001 PCM specified filter and in Australia we have RYCO Z9 filter as replacements specified generally available at any auto shop so instead of paying $50 from local Nautique dealer for R077001 filter I’ll be using the $10 RYCO next oil change. Also PCM state clearly use a mineral oil for most of their engines so don’t waste money on synthetic oil especially when changing each yr as recommended.
          • Nautiquehunter
            • Jun 2008
            • 2080
            The correct Fram number is POS- JUNK.
            • RDT-G23
              • Jun 2017
              • 589
              • TEXAS
              • 2020 G23 PARAGON I 2017 G23(sold)
              I use the proper Mobil 1 filter on mine, FWIW-with Filter Mags on it...
              • GMLIII
                • May 2013
                • 2799
                I change the fuel/water filter separator at each oil change. The FCC fuel filter I change ever 200 hours. I order these in bulk when I order my PCM oil filter from Nautique Parts. Generally I order 4 oil filters, 4 fuel/water separators and 2 FCC fuel filters at a time.
                • greggmck
                  • Oct 2014
                  • 795
                  • Bellevue WA
                  • 2023 Paragon G23
                  FYI. This cross reference and test result chart has been around on the forum for a few years.
Name:	Oilfilter Ratings.JPG
                  • RDT-G23
                    • Jun 2017
                    • 589
                    • TEXAS
                    Don't forget your Filter Mags for you anal-retentive types...
                    • greggmck
                      • Oct 2014
                      • 795
                      • Bellevue WA
                      • 2023 Paragon G23
                      Yes. Oil Filter Monthly is a wonderful mag. I especially like the articles about how to make yard art from old oil filters!
                      Sent from my SM-G965U using Tapatalk
