** HELP - 2007 5.7L - DIED and won't start!
  • mmadore21
    • May 2015
    • 4
    • Cumberland, ME
    • Ski Nautique 206 (2007) - 5.7L PCM GM Vortec
    2007 Ski Nautique (206 - open bow)
    5.7L PCM GM Vortec
    625 total hours (150+ this summer)
    We are in Maine - ski hard May - Oct - 150 hours this summer
    Issue:
    DIED after planing out! Warmed it up for 5-10 min while shuffling ski gear. Putted 2 minutes out of cove into open water. Plained boat out and it died. Paddled back for 30 minutes with 2 water skis.
    Boat is meticulously maintained. Wires, plugs, cap, rotor, fuel filters, oil, marine stable, impeller...all done when they are supposed to and regularly. Like many of you, she is well maintained.
    Before hauling out of water I checked the following: kill switch, spark, fuel pressure, fuel cell and filter, small inline fuel filter, plugs, wires, cap and rotor. Plugs, cap and rotor and a new coil were all less than 30 hours old. The boat had no issues ever until the cam position sensor went about 25 hours ago. That was replaced. I replaced the coil when I was trying to diagnose the cam position sensor issue which was professionally diagnosed by throwing the relevant code.
    Mechanic (at a Nautique dealer) His Notes: "scanned the computer and found no codes and no sensors that show any readings that are out of parameters. I have changed the crank position sensor, cam position sensor and ignition coil and driver as well as the ECM with good known parts off of an engine in the shop. I have checked compression and that appears to be ok, I have also changed the distributor gear as it showed some pretty decent signs of wear. At this point in time it looks like there may be an internal issue with the motor probably leaning towards the camshaft but i would have to dig a little deeper to be sure."
    "The motor is acting like it is being told when to inject fuel and fire at the wrong time, hence me thinking it could be a camshaft issue, which could also be a timing chain or gear issue or it could be the woodruff key on the crank that holds the bottom gear or the reluctor wheel on the crank for the crankshaft sensor. Basically I will need to dig into the motor and see if I can pin point it with going in as little as possible. The first thing that I would like to do is pop the exhaust and take the valve covers off, this will give me a good idea if the camshaft is doing what it is supposed to be doing on all cylinders. If that all looks ok then we will have to dig further and the next step would be remove the front drive accessories see if we can get the timing chain cover off. A lot of the time the motor has to be pulled due to the fact that the cover has a lip that sits inside of the oil pan and usually cant be removed without taking the pan off. "
    Thoughts?!?!?
    Here are 2 vids of trying to start it:
    https://youtu.be/jYGKh-ha0bg
    https://youtu.be/WyRo_gzty48
    Since we are in Maine they are doing 500 winterizations and won't be able to look into my boat until December. It's killing me to store it broken.
    Thoughts?!?!? Suggestions.
    Thank you for your time.
  • scottb7
    • Aug 2011
    • 2198
    • Carson City, Nevada
    Yeah, i doubt it is anything real serious. Just maybe hard to figure out. Friend of mine had a wire of his fuel pump relay shorting out against the engine, for example.
    You checked yourself to verify spark? If it was me I would spray a bit of starting fluid down throttle body and see it would run a bit. If so then you know it is fuel system. And you would feel better about that serious stuff...
    • mmadore21
      • May 2015
      • 4
      • Cumberland, ME
      Thanks for the suggestion. Since it's in my driveway and I'm cleaning the hull as we speak I went out and just tried it. No luck. Sprayed starting fluid down throttle body like you suggested...tried to start it. It just made some sharp backfire like gasps (bad description)...but otherwise sounded like the video I posted.
      • Randy1833
        • Sep 2017
        • 25
        • BC
        • 2017 Super Air Nautique 230
        Did it go into limp mode? My 5.7 died a few years ago, would only idle back to the dock. Thought is was my throttle sensor, but ended up that one of my dual batteries wasn't holding a charge and was throwing the computer off. The boat goes into limp mode as soon as it senses a fault, so you don't do more damage. Put in a new battery, and all fixed. no problems until I sold it this year and bought my 230. Good luck.
        • DW SD
          • Mar 2015
          • 416
          • San Diego county
          • 2001 SAN 210
          Shouldn’t have compression if cam timing skipped. Or if timing chain or gear failed.
          • DW SD
            • Mar 2015
            • 416
            • San Diego county
            • 2001 SAN 210
            Well it wouldn’t have uniform compression at least.
            • jmo
              • Mar 2006
              • 707
              • MA
              Have you considered taking it over the border to NECC boats? They don't sell CC anymore but they still service them and Fred is really good. They are in Rochester, NH.
              They were the CC dealer in New England for over 30 years...
              Where in Maine are you? I don't think long lake marina has been a CC dealer very long so I wouldn't take it there for service if it was me...
              ______________________________________
              2006 SN 196 Limited Excalibur
              2001 Super Sport Limited GT40
              2018 Ski Nautique 200 TE, H6
              • Quinner
                • 2246
                • Correct Crafts
                Did you try a new cap and rotor?
                • kcoben
                  • Sep 2016
                  • 33
                  • Akron,Ohio
                  • 2009 SANTE 210
                  Fuel pump?
                  Sent from my SM-G930P using PLT Nautique mobile app
                  • Mr Fix It
                    • Sep 2018
                    • 2
                    • Denver, NC
                    • Proud owner of 2008 SV211 Nautique
                    what was found to be the issue?
