Pcm transmission service
  • kcoben
    • Sep 2016
    • 33
    • Akron,Ohio
    • 2009 SANTE 210
    Can't seem to suck out much fluid, have proper Holt brand sucker. But can't get much out
    Sent from my SM-G930P using PLT Nautique mobile app
  • Blamey
    • Sep 2015
    • 595
    • New York
    Try make sure you are going in straight you can end up going down the wrong way.
    If you put the dipstick back in if there is still oil on it that means there is more oil to remove.
    I did this yesterday and got about a quart out.
    I'd recommend getting a piece of straight copper tubing and using this as it's easier to keep straight and the plastic can get stuck if in goes down the wrong hole.
    • kcoben
      • Sep 2016
      • 33
      • Akron,Ohio
      • 2009 SANTE 210
      Nothing worse than going down the wrong hole, thanks for the info
      Sent from my SM-G930P using Tapatalk
      • Infinity
        • Sep 2017
        • 730
        • Lake Norman - Denver, NC
        • 2014 SV244 w/ ZR409
        Only holds about a quart n half
