Which RV Antifreeze?
  • Evening Shade
    • Apr 2015
    • 1295
    In the past I've always just drained the water out of the engine when I winterize. I think this year I will drain the water and then draw RV antifreeze into the engine mostly for corrosion protection.
    I've read some reviews on the net where people have said that the -50* pink AF has failed below +10*F. I did some research and found that there are some blue RV AFs that are rated at -100 and -200*.
    So what is everyone using, the pink -50 or the blue -200* AF?
    It seems to me that a dry block or a wet block with the blue -200* AF would be better than using the -50 AF if temps drop down to the single digits.
  • vanhanbr
    • Mar 2014
    • 223
    • Wisconsin
    • 2008 SAN 210
    The -50 stuff causes more corrosion than water, I no longer use it for that reason. -75, -100 antifreeze or vehicle antifreeze is the way to go.
    2008 SAN 210
    1997 Sport Nautique
    • Nautiquehunter
      • Jun 2008
      • 2080
      I use automotive green antifreeze in my boats . Up north 50/50 mix giving a -32F freeze point . Here in Ga I mix 30/70 giving a 0 to +10 freeze point. All my boats are stored inside buildings. If you use the green antifreeze make sure you put a catch bucket under the exhaust and run it in the spring . DON'T put it in the lake.
      • Evening Shade
        • Apr 2015
        • 1295
        How do you dispose of the green AF when you flush it out in the spring?
        • Nautiquehunter
          • Jun 2008
          • 2080
          There are disposal sites I keep most of it for next year . Our winters here are only 2 months long so the anti freeze coming out is still good. Just have to top it off with a little new next year.
          • thtrog
            • Apr 2012
            • 112
            • Asheboro, NC
            • 2014 G23 450
            I use Prestone http://prestone.com/products?detail=AF222
