Walmart RV antifreeze in engine?
  • Liamfm
    • Aug 2017
    • 74
    • Vermont
    So, only kinda freaking out. Boat is in storage with the Walmart RV antifreeze in it. Storage is unheated. Might see -10f here in Vermont. Today I'm at my local Walmart and look again at the product. While it says RV/boat, the fine print says "not for use in engines" or Marine engines. Can't remember which.
    Should I be worried?
    Sent from my XT1575 using PLT Nautique mobile app
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    When they say "not for use in engines" they're most likely referring to using it in a closed-loop radiator/heat exchanger. That's not what you're doing. It's simply sitting there keeping your block and heater core from freezing.
    -Charles
    • Blamey
      • Sep 2015
      • 595
      • New York
      "Due to its slightly lower cost, some boaters prefer to use our Seafit brand -50°F Marine and RV Water System Antifreeze, which is a propylene glycol/alcohol blend. This is fine for potable water and sanitation systems, but is not recommended for winter engine storage, since some of the alcohol can evaporate, resulting in reduced protection towards the end of winter layup."
      This is on the West Marine site. If I were you I'd do some more research
      • Riddlen4u
        • Sep 2017
        • 16
        • Spruce Pine NC
        • 2000 Moomba Möbius, 2006 Möbius LSV, 2013 G23
        I had to use the same type as you because the glycol based wasn’t available locally. I wouldn’t be too concerned about evaporation with it being sealed but it will dry out hoses and seals. Next year I will plan better.
