Fuel system moisture
  • nautiquesteve
    • Nov 2015
    • 14
    • Fort Wayne, Indiana
    • 1988 Ski Nautique 2001
    I have a 1988 SN 351PCM. Does Correct Craft recommend or not recommend using "HEET" in the gas tank?
    Thank you
  • Nautiquehunter
    • Jun 2008
    • 2080
    Do you have a water problem? For winterizing I use marine Stabil in the gas.
    • GMLIII
      • May 2013
      • 2797
      Nautiquehunter , I use regular Stabil in my winterization process and often thought about using the marine grade Stabil as an option but passed on it due to the increase in cost. What are the pros of the marine grade vs regular Stabil?
      • Infinity
        • Sep 2017
        • 730
        • Lake Norman - Denver, NC
        • 2014 SV244 w/ ZR409
        Marine grade (blue) specifically "bonds" to water/condensation so it can safely burn off. I use both red and blue, but always use only blue a month before winterizing and top off fuel tank to reduce the area in tank that condensation can build up.
        • GMLIII
          • May 2013
          • 2797
          Great thanks for explaining
