I’m winterizing my 2017 G23 for the first time (with a tech). Henceforth, I'll do it on my own. That said, I understand winterizing with a heater is kind of a pain. Can anybody opine? Thanks.
A d m i n i s t r a t o r
- Mar 2002
- 16498
- Lake Norman
- Mooresville, NC
On the H5/H6, they will all have the blue plugs and are super easy to drain. Takes all of five minutes. The only thing that doesn't have a plug is the heater, and that just requires disconnecting the two red hoses and introducing air pressure into either one to force the water out of the other.
Here are the drain locations for the H5 and H6 (NON-Coastal):
Here are the drain locations for the H5 and H6 (Coastal):
Note: If your boat is a Coastal Edition, there is no need to winterize the heater because it will have antifreeze in it already.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Apr 2015
- 1295
- Martinez, GA/Lake Greenwood, SC
- 2017 GS20 Previous: 2011 SAN 210, 2007 Malibu Wakesetter 23LSV, 1995 Cobalt 200
Great diagram here. Don't forget to empty the strainer cup as well.
Jeff, what about draining the tranny cooler? It isn't mentioned in the above diagram.2007 Malibu Wakesetter 23 LSV, 1995 Cobalt 200
- Apr 2015
- 1295
Originally posted by sixcampbells View PostGMLIII - please validate my comment on the tranny cooler. I feel confident it's correct based on where the data came from but you never know. I would hate for something bad to happen...... Maybe somebody else will comment here and help validate what I heard.2007 Malibu Wakesetter 23 LSV, 1995 Cobalt 200
Originally posted by NautiqueJeff View PostOn the H5/H6, they will all have the blue plugs and are super easy to drain. Takes all of five minutes. The only thing that doesn't have a plug is the heater, and that just requires disconnecting the two red hoses and introducing air pressure into either one to force the water out of the other.
No trans cooler plug shown on the diagram above, that would be pretty good validation from me. If you want to double check just locate the cooler and follow the water lines to/from, if there is a plug downline and lower then the cooler, you are double validated!
It turned out to be quite easy. We pulled all of the plugs and a heater hose as well. We drained/cleaned the strainer cup also. It is a shame we can't run the engine with some fuel/two cycle oil or fog them in some way. I'm told the catalysts are the reason not... Boy, I sure don't like the catalysts. From having my boat delivered without one of them in the exhaust manifold, to them causing more heat in the engine compartment, to well, just about everything-I don't like 'em...
This is my first time winterizing my nautique G23 with the H6 motor. I live in South Carolina now and have pulled the drain plugs including the v-drive and transmission cooler hose. I also pulled off and drained the hoses to the heater and blew them out with low pressure compressed air Do I need to run RV antifreeze through the engine? My dealer said they did? If so what is the best way to get the RV antifreeze in the engine with the boat on a lift over the water? I have a fresh water flush but I am thinking that will not work without pressure.
Thanks,
Brian
- May 2013
- 2795
- Smith Mountain Lake, VA (Craddock Creek area)
- 2017 G23 Coastal Edition H6 | 2001 Sport Nautique | 1981 Ski Nautique
I'm hoping you do not have to use any antifreeze but I'm not entirely certain . I'm curious as to the responses you receive on this thread since I have a 2017 G23 with an H6
- Mar 2002
- 16498
- Lake Norman
- Mooresville, NC
I never use antifreeze in mine. Just be sure to get all of the water out. If I lived in a colder climate, I might consider it, but here in NC, as long as all the water is out, I feel plenty safe. I have five engines in my Nautiques here, and haven't run antifreeze in them over the winter for many years.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Biggest reason for the AF, IMO, is the anti-corrosive qualities...no way to get every drop of water out which can cause some corrosion over winter months (I am also in NC), so I do the AF to prevent corrosion and have little more peace of mind when it gets cold, tho I am sure its not needed for that.
- May 2013
- 2795
Originally posted by NautiqueJeff View PostI never use antifreeze in mine. Just be sure to get all of the water out. If I lived in a colder climate, I might consider it, but here in NC, as long as all the water is out, I feel plenty safe. I have five engines in my Nautiques here, and haven't run antifreeze in them over the winter for many years.
