Prop Puller
  • Otto Throttle
    • Oct 2017
    • 38
    • Cleveland OH
    • 1999 19'6" Masters Edition
    Prop Puller
    I like to have the correct tools for the job, what would be the options/pros and cons on a prop puller. It is for a 1999 19'6" with a 4 bladed prop. Also possible suppliers would be great too.
    Otto
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Something like this will work fine: https://www.overtons.com/modperl/pro...uller&i=321428
    • Otto Throttle
      • Oct 2017
      • 38
      • Cleveland OH
      Thank you!!!!!!
      Otto
      • scott resick
        • Jan 2012
        • 532
        • Pittsburgh
        • 2006 196 Limited
        Actually, that c clamp puller will not work on a 4 blade. I just went through this myself. You will need a harmonic puller.
        Wakemakers.com has them for around 40 bucks
        • charlesml3
          • Jan 2008
          • 2454
          • Lake Gaston, NC
          • 2022 G23
          Nonsense. I've pulled the prop off my old 99 Air Nautique (with a 4-blade prop) using this puller several times. And my buddies 2001 Sport and his neighbors 2002 Super Air, all with 4-blade props.
          If you look at the link I posted, someone there also asked and it was confirmed this will work with a 4-blade.
          -Charles
          • Otto Throttle
            • Oct 2017
            • 38
            • Cleveland OH
            How do you use a harmonic remover? videos for the C clamp remover looks a lot easier to use and straightforward. Can someone really confirm those work with the four bladed prop.?
            Otto
            • shag
              • 2217
              I have used a 'C' style remover on both 210 and 230 4 blade props with no prob. Leave the nut on a few threads after loosen it and before you pop the prop lose to prevent the prop hitting the ground. I also put an old towel or moving pad down in case I drop it...
              • philb
                • Jan 2009
                • 125
                • Australia
                Yep.... C Clamp works on 4 blade!!
                • scottb7
                  • Aug 2011
                  • 2198
                  • Carson City, Nevada
                  https://www.youtube.com/watch?v=sXcmT_ftlSM
                  I have used both, and have both...There is no right or wrong or better or worse or easier...Just two ways of doing..
                  • 2001SAN
                    • Apr 2012
                    • 203
                    • Ireland
                    • 2001 Super Air Nautique 210, 1989 Fairline Corniche 31
                    -Charles
                    Agreed. Used mine on a 4 blade countless times.
                    D.
                    • Kevin_B
                      • Jan 2008
                      • 313
                      • Greensboro, NC
                      • 2008 SANTE 220 1990 Sport Nautique
                      Is the claw style better than Harmonic? Stands to reason claw would be better for a stubborn prop. I need one and wondering what is the best bang for my buck. Keep in mind I don’t foresee using it often (hopefully).
                      1990 Sport Nautique
                      • charlesml3
                        • Jan 2008
                        • 2454
                        • Lake Gaston, NC
                        • 2022 G23
                        I don't really think one is any better than the other. They both do the same thing. I have one of the C-Clamp style pullers and never had any trouble getting a prop off with it.
                        -Charles
