Factory 4 bade prop vs. New Acme
  • Otto Throttle
    • Oct 2017
    • 38
    • Cleveland OH
    • 1999 19'6" Masters Edition
    Newbie Question....1999 Nautique closed bow with 290 hp option and factory 4 blade prop. I just bought the boat and noticed a little prop damage one 1 blade. No vibration at any rpm or speed. Quandary...should I have it repaired or should I keep it as a spare and get an Acme 4 blade? Also if buying an Acme should I go with same pitch. I was getting 45 mph at 4400 rpm according to perfect pass. Can someone give me the pros and cons on this please?
    Starts
    11-29-2017
    Ends
    11-29-2017
    Otto
  • bandit628
    • Sep 2016
    • 318
    • Southern Illinois
    • Current-2012 SANTE 210 Past Boats 2000 Mastercraft
    Call them. If you buy a new one, they might fix your current for free or at discounted price.
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      You should always have a spare prop. It can easily be a "weekend saver." If the one you have is doing everything you need it to do, then just buy another with the same specs and have your current one repaired.
      -Charles
      • MLA
        • Dec 2009
        • 1312
        • Lake Wylie NC Area
        Prop technology has come a long way since 99. Depending on the gear ratio and how you use the boat, a 4-blade may not be the best choice.
        • scottb7
          • Aug 2011
          • 2198
          • Carson City, Nevada
          If there is no vibration, then there is no reason to repair. I agree that you should consider having a spare. But on what you should buy you gotta determine if you want more speed out more power or whatever...No one can advise you until you decide what you are trying to accomplish.
          • Otto Throttle
            • Oct 2017
            • 38
            • Cleveland OH
            Through research I found that if I go 422 it would be the best choice. It's a proven performer on that hull. About the best you can get outside of special needs application.
            Top speed won't change much but everything else will be light years ahead. Better hole shot, better mid range punch, easier speed holding, better tracking/handling, quicker stopping when you chop throttle and leave it in gear.
            Otto
