Compartment Carpet Options
  • srock
    • Oct 2008
    • 1066
    the carpet in the compartments is coming off the walls and floors are a little beat up. Anyone replace or us an alternate material? You cannot see the sidewalls but it is peeling off.
  • Wake.BC
    • Jan 2016
    • 423
    • BC, Canada
    Gaterstep!
    I know some have sprayed bedliner too
    • srock
      • Oct 2008
      • 1066
      I thought about that just did not know if it could be done neatly in closed areas.
      • ScooterMcgavin
        • 1478
        • 2014 SAN 210 TE
        It can.. And also can be rolled on vs spraying. Just mask and tape off areas you don't want it. Im sure spraying is ideal but if it's to tight in there you'll have to improvise.
        1989 Sport Nautique
        • srock
          • Oct 2008
          • 1066
          Seems like a much better solution than the carpeting which is somewhat a dirt and mold trap.
          • Blamey
            • Sep 2015
            • 595
            • New York
            what's the price diff between gator step and Seadek. I would like to redo my compartments with bedliner on the side and seadek or gator step on the floor.
            • srock
              • Oct 2008
              • 1066
              https://www.rubberflooringinc.com/pl...&popup=samples
              i used this in the trunk of my old malibu. Was great for circulating air under stored items.
