Fuel Control Cell diameter
  • functionoverfashion
    • Jun 2017
    • 509
    • New Hampshire
    • 2003 SANTE
    Can someone with easy access to their boat please tell me the diameter of the PCM Fuel Control Cell canister? I'm trying to order a filter wrench specifically for that, and my boat is in storage for the winter.
    Thank you in advance!
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Pretty much any automotive filter wrench will be fine. Or you can just go with one of these: https://www.amazon.com/Craftsman-Pie...s=strap+wrench
    A strap wrench has a really big range of sizes it'll grip.
    -Charles
    • homer12
      • Feb 2016
      • 584
      • Indianapolis, IN
      • 2004 SV211 TE
      Canโ€™t tell you the diameter but can tell you Iโ€™ve used one of those rubber strap wrenches effectively on mine.
        • Jun 2017
        • 509
        • New Hampshire
        • 2003 SANTE
        I'm looking at a somewhat adjustable strap-style wrench, but I've had trouble in the past with the one I have, specifically on trying to remove an FCC on these engines.
        This summer, I tried my existing strap wrench on the FCC and couldn't get it off. This is the one I have (18" handle)
        Click image for larger version  Name:	31h%2BwOLWV-L.jpg Views:	1 Size:	16.7 KB ID:	544034
        I was considering one more like this
        Click image for larger version  Name:	61Vo6kT8jwL._SL1107_.jpg Views:	1 Size:	26.2 KB ID:	544033
        that uses a metal band, and can be turned with any ratchet + extension. But these come in a relatively small size range, as do some alternatives, like...
        one of these, for the same reasons - you can use a ratchet with any kind of extension or adapter you may want, to fit in tighter spaces.
        Click image for larger version  Name:	s-l225.jpg Views:	1 Size:	9.0 KB ID:	544032
        I am hoping that once I've had it off, it will not be so difficult to remove again if I don't overtighten it. There have been a few things on this boat that were waaaayy tighter than I think they needed to be, like the oil filter, and now this.
        But I need the approximate diameter to figure out which size tool to buy.
        Charles, I may try one of the ones you posted at least because they're not expensive! But I was able to put a LOT of force on my existing strap wrench and it didn't budge. I'd be afraid of breaking the plastic handles on the Craftsmans....
        • charlesml3
          • Jan 2008
          • 2454
          • Lake Gaston, NC
          • 2022 G23
          You're not going to break the plastic handle. You'd only do that if you somehow put a pipe on it and over-leveraged it.
          The only "problem" with these strap wrenches is the sometimes really tight quarters you have to work in. Sometimes it's difficult to get it in a position where it gets enough bite before the handle runs into some part of the engine, a bulkhead, etc. I had to really work mine around to find the right spot to get the fuel/water separator off of my 230.
          From the factory, my filters were WAY too tight. It was all I could do to get them off. Since then I only tighten them by hand.
          -Charles
            • Jun 2017
            • 509
            • New Hampshire
            • 2003 SANTE
            -Charles
            Hmm, thanks. I think in my boat if you take out the side panels by the engine, you can get a decent bit of leverage. Without that, forget it. This fuel filter housing will definitely NOT be going on as tight as it is right now. But I didn't change the filter this year (I got the boat in June and it had already been running) so next year it's a must.
            • charlesml3
              • Jan 2008
              • 2454
              • Lake Gaston, NC
              • 2022 G23
              Yea. I changed mine at 25 hours. After an hour of struggling, sweating and cursing, I FINALLY got the strap wrench back far enough to get a bite and the filter moved about 1 degree.... Yea. After about 20 more of those I could finally turn it by hand.
              I'm convinced the factory puts those filters on with a wrench.
              -Charles
                • Jun 2017
                • 509
                • New Hampshire
                • 2003 SANTE
                -Charles
                This is why I'd like to get a tool that can work in close quarters, by having an extension that gets the wrench up and above the whole canister. I'm still looking at getting one of the tools I posted above; however, for the money I think I'd pick up a set of the craftsman ones, too - I'm sure they will fit and work in some places my 18" one will not.
                I would gladly pay $20+ for a tool that will save me an hour+ of frustration when I go to change this thing in the spring.
                • charlesml3
                  • Jan 2008
                  • 2454
                  • Lake Gaston, NC
                  • 2022 G23
                  Yep, totally agree with you. If the nearest store that sold tools hadn't been an hour one-way, I'd have gone in search of another tool. Since then it's been fine. I still have to use the wrench to get it going, but I now know exactly how to position it right the first time and it comes off easily. You know how that goes. First time takes 10 times longer...
                  -Charles
