When to replace the distributor cap
  • keithh2oskier
    • Jul 2015
    • 126
    • Sacramento
    • 02 Ski 196 SE
    Is there an approx hour on when to replace the cap? I have an 02 196 with the 5.0 and I would assume its the original cap. Hours are low, 230. Runs fine but need to order a replacement impeller and wondering what else might need to be done at the same time.
  • Nautiquehunter
    • Jun 2008
    • 2080
    My 08 210 has over 1000 hours on the original ignition . If it aint broke don't fix it .
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      There are a couple of ways to know. The most obvious is a ignition skip. You'll hear and feel it when it just misses because one cylinder didn't fire. The boat will also be down on power.
      Next, you can visually inspect it. Get it off the distributor and take a look at the contacts inside. If they're worn and pitted, it's probably time. You should replace the rotor at the same time.
      -Charles
      • scottb7
        • Aug 2011
        • 2198
        • Carson City, Nevada
        Distributor and rotor are not listed on a maintenance schedule but I would go ahead and take a look at them every 5 or 600 hundred hours and maybe replace. I bought mine for my 210 on ebay for $15 bucks for my 2008 210. Who knows maybe you get better gas mileage.
