2018 SAN 210 tow pylon retrofit/aftermarket?
  • Zride
    • Dec 2017
    • 44
    • California
    Totally stoked about my new boat although I am questioning the thought as to why they would leave out the tow pylon. I want to install an aftermarket or oem pop up pylon. Any ideas how I can get this done either factory accessory or aftermarket? Thanks for your replies
  • GMLIII
    • May 2013
    • 2797
    I would agree a pop up pylon should still be an option on the 210-230 and G series Nautiques. There are many uses for these even though these boats are primarily wakeboard/wakesurf boats.
    • jondavis08
      • May 2016
      • 369
      • Battle Creek, MI
      • 2014 SANTE 210 2003 SANTE 210-Sold
      This is my the main flaw in 2014+ 210s in my opinion. I ski on my 2014 210 often and it’s a decent wake. I looked into this and haven’t found a solution yet. Thought I could put a pop up one where the lift ring is located. Was told that the lift ring is meant to be pulled upwards and adding a pulling force to the supports may fail. If you find a way to add one if love to know
