98 196 steering wheel free play
  • DW SD
    • Mar 2015
    • 416
    • San Diego county
    • 2001 SAN 210
    Hi. Thanks for the info. Are the bearings really bushings? Bushing would have no moving parts. Sorry just trying to picture this. And thought I’d do this at the same time as the steering cable in my 2001.
    If you still have the bearings I’d love them if you think they’d fit my 2001. Thank you!!!
    • Calisdad
      • Jul 2017
      • 20
      • Dallas, Oregon
      • 98 Ski Nautique
      yes they are just polymer bushings. Pull up the part on Graingers and have a look. I'm pretty sure we have the same helm.
      • Calisdad
        • Jul 2017
        • 20
        • Dallas, Oregon
        • 98 Ski Nautique
        I received the parts from Grainger last night. They are freakin perfect!!! All ya need to do is trim one down about 1/8" and you're good to go. The original bushings are too short and leave a section of shaft that is without a bearing... so I trimmed one just enough to allow everything to go back together. Make sure to replace both bearings... just remove the top snap ring and pull the shaft out through the bottom and you'll figure it out. You get 5 bearings per pack. I have 3 left over if someone wants me to mail a couple let me know✌️
        Go to Grainger.com I wish I hadn't installed a new helm... the parts were around $15 shipped vs $180 for a new helm
        IGUSPolymer Flanged Clip Bearing with 3/4" Inside Dia. and 13/16" Outside Dia.
        • Item # 2NCG9
        • Mfr. Model # MYI-12-12
        • Catalog Page # N/A
        • UNSPSC # 31171506
        • DW SD
          • Mar 2015
          • 416
          • San Diego county
          • 2001 SAN 210
          • MeisterJaeger
            • Apr 2016
            • 2
            • Vancouver, WA
            • 1998 Ski
            Maybe this (a few pics) will help? There appears to be a second set too of similar (different size) of bushings on the horizontal (tilt) axle of the helm. Mine seemed perfectly tight. Ordered my bushings via Amazon Prime.
            Still a bit of play...it seems like the splines are worn, not sure if it’s the shaft or the wheel hub...I’ll see how it drives in a few weeks and go from there.
            • srock
              • Oct 2008
              • 1066
              #21
              When the steering gets stiff, it there any potential that the cable breaks before it is replaced.
