OK, I KO'd a log this year. Acme couldn't repair the prop, so replaced it. Also, the rudder is bent backwards as well. Time to fix the problem. Anyone have a machine shop experience with straightening the shaft? New rudders approaching $700. Thanks
Ouch! 700 that’s crazy, so glad I had mine replaced under warranty.
I would definitely want to make sure it is alined properly, I’d watch for a used one too.
If you do end up needing a new one, order from NautiqueParts and use our discount code (PND) for 10% off. That gets the cost down to about $620.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
