Anyone have any idea where I would be able to find a replacement circuit breaker panel with hole for battery switch that is located in the rear locker of the 210s? Plastic housing was cracked and thrashed when I bought my boat from previous owners and would love to finally get it cleaned up. Nautiqueparts I see has a entire replacement unit (obviously unnecessary) but also doesn't even have the battery selector switch in that version. Anyone been able to track down a replacement plastic housing or just ended up having new ones fabricated? I assume something custom might be better as the original plastic one looks like it wouldn't even have held up now with fat sacs in the rear.
I had the same issue several years back on my 06, the ballast bags gave that panel a rough time. I forget where I got it from, but someone tracked down a complete set with the plastic housing, metal panel, and all the components Fromm an '10 model. They only charged me like $130 for the entire lot and I did not know I was getting all the relays and breakers until I open the box. It was either DIM, nautique parts, or nautiques of Orlando. I believe they had to call the factory to get it tracked down which did take a few weeks. Not a standard item
Sent from my Pixel 2 using PLT Nautique mobile app
2013 SAN 230
2006 SSN 210 (SOLD)
