Repairing a soft trailer step
  • Searay
    • Sep 2003
    • 51
    • Northeastern PA
    I have a 1996 Correct Craft trailer that the steps on each side are getting soft on due to the plywood rotting. I was wondering what others have used to make this repair. The plywood and carpet again? It seems to hold a lot of water that is also causing the frame to rust where the carpet makes contact. Maybe spacing the plywood from the frame would help. Has anyone used diamond plate or other material? Thanks.
  • jhiestand
    • 778
    • Columbus, Ohio
    • 08 Super Air 210
    I know Grant has done some replacement work on his trailer. I think I've seen some posts elsewhere that folks have used diamond plate, too.
    Check Grant's trailer here. (http://svtsupercharged.com/gallery/dhm)
    I'll be due for a trailer overhaul soon, too. Yellow_Flash_Colorz:
    '08 Super Air Nautique 210
    • EchoLodge
      • Jan 2004
      • 616
      • Huntington Beach, CA
      • 99 Super Sport
      My 1990 trailer is doing the same. I will be making replacement parts out of 1/4 inch aluminum.
      sigpic
      • Searay
        • Sep 2003
        • 51
        • Northeastern PA
        Does anyone know what Grant is using for step material?
        • noti_dad
          • Jan 2005
          • 214
          Carbon Fiber. LOL!
          • darrel409
            • Jul 2004
            • 566
            • San Dimas, So. Cal
            Option A:
              • 2908
              Grant's are polyethelene, similar to the cutting board material. But you probably don't want to go that route, he had to install steel plate underneath because the material was not strong enough by itself. Plastic steps might work great but finding a material that is thick enough and stong enough might be challenging.
              • ccskier16
                • Nov 2003
                • 92
                • Hartland, WI
                • 2006 Ski Nautique 1974 Skier 16 1991 Ski Nautique, former
                I had the same problem on my 91 when I got it in 2003. The conclusion I came to is that it lasted 12 years that way and I might as well just replace it like Correct Craft originally did it except leaving space like you suggest against the frame. It was good for a rainy day. No bling, but practical.
