Tandem axle tire wear problems?????
  • MNSuperAir
    • Sep 2005
    • 591
    • St Paul
    • 2016 SAN 210
    I have a Dorsey tandem axle trailer for my 2001 SAN. I have noticed that my rear tires are wearing much quicker than the front tandems. After measuring the trailer height I think my reciever is 2" low. But wouldn't you think the ceciever being low would put more weight on the front tires and wear them quicker? I'm confused. Has anyone ever noticed this.
    Thanks for your help
    2016 SAN 210
    2006 SANTE sold
    2001 SAN - sold
    1991 Sport Nautique - sold
  • tdc_worm
    • 532
    RE: Tandem axle tire wear problems?????
    because you have more weight on your front tires, that is causing them to be the pivot point of the trailer when turning (and rarely to you ever drive a directly straight line). if the front tires are the pivot point, then the rear tires are being dragged more latteraly across the asphalt when turning, resulting in more wear...
    • Onthewater
      • 695
      • Near the cheddar curtain
      yep, what tdc said
      main reason i like single axle trailers. easy mobility and no wear issues
      I don\'t care.
      • tdc_worm
        • 532
        Re: RE: Tandem axle tire wear problems?????
        Originally posted by Onthewater
        the flipside is the tandem axle trailers tow beter in my opinion...they jerk the vehicle less and reduce tongue weight on the hitch. all you have to do is buy the appropriate hitch for the appropriate tow height to eliminate that problem. i have been towing the same boat 20 miles round trip to the lake for three years and (300 hrs of run time) and have yet to see any significant tire wear... i did have to buy a different hitch when i traded vehicles, though....
        • Jesse1
          • Sep 2004
          • 78
          • East Texas
          RE: Re: RE: Tandem axle tire wear problems?????
          You're going to have a certain amount of wear from tire scrub during turns. Like TDC said, get the proper height hitch. Then rotate the tires once a season.
          • ihaveansv211
            • Oct 2005
            • 164
            • New England
            whats the wear pattern look like? even? one side?
            www.shredcandlewood.com
            • MNSuperAir
              • Sep 2005
              • 591
              • St Paul
              • 2016 SAN 210
              The wear pattern is acting like the tire pressure is low. It is wearing towards the outside of the tread. I checked the tire pressure and it is at 55psi. which is 5psi over recommended. The tire even squats a little compared to the front tandem.
              Got the right hitch, lets see if that fixes it.
              2016 SAN 210
              2006 SANTE sold
              2001 SAN - sold
              • wake_fun
                • 1330
                • CA
                • 1995 Super Sport
                Rotate them often.
                Photo Album
                Ballast Install 1
                Ballast Install 2
                Amp Install
                PPass Install
                Alternator Install
