2006 bent rudder
  • COOLDAD101261
    • Mar 2015
    • 10
    • Sydney
    • 2006 226
    2006 bent rudder
    Hi Guys , I have a 2006 226 and on the weekend I hit something in the river and slightly bent the rudder.
    The boat still steers ok but steering in a bit tight , and the rudder is now slightly rubbing on the brass housing on the boats hull .
    Dose this need to be removed and replaced ?
    if so could anyone help with steps to remove the rudder .
    Thanks Mark .
  • Jonny Quest
    • Aug 2014
    • 384
    You need to drop the rudder and have it straightened. With a V-drive, that will be a bit of a chore. As long as you are down there, be sure to replace your rudder shaft packing.
    JQ
    • COOLDAD101261
      • Mar 2015
      • 10
      • Sydney
      • 2006 226
      Thank you .
