can anyone help me?, I'm trying to remove the side console that houses the morse control and radio. I have all the panle retaining screws and drivers seat and dash out. Could not get the panel over the throttle lever, how do I remove the throttle lever so that the panel can be removed. I think it should be possible to remove the lever from the assembly behind the panel. I removed the screw in the button but nothing moved.
It has a allen head set screw in the very bottom of it that you have to unscrew before you can reomve, the trim ring is notched so you can get to it.
CC never answered any of my emails.
Try a good dealer instead!
I've had success with http://www.miamiskinautiques.com/
Good luck!
