SV211 issues
  • Ginger89
    • Oct 2017
    • 8
    • Ohio
    SV211 issues
    I am looking at a SV211 that has a couple small problems. The first problem is the perfect pass is stuck in its lowest setting. Would I need a whole new module or just a new cluster? The oil temp gauge is also not working so I was unaware if that was a sending unit issue or the gauge itself. Any help would me appreciated.
    Thanks,
    Nate Keeton
  • beamons
    • Jun 2017
    • 376
    • Utah
    I am not sure what you mean about being stuck in the lowest position. If this is not the GPS PP it is often upgraded to it. This usually cost 800-900 for the GPS part and the new needed gauge.
    The oil temp gauge is also could be either but unfortunately it might be a whole different issue - unfortunately not a good one.
    https://www.planetnautique.com/vb5/f...-faria-gateway
    Provide a little more info about each and I think many people could be helpful.
