Engine code DTC 0174
  • Jmoesdad
    • Apr 2017
    • 12
    • Orlando
    • 2011 sante 230 1999 Mastercraft Maristar 1990 Bare
    Anyone have this issue? 2011 sante230
    I keep getting this, switched fuel, added additives etc. I may swap 02 sensors first to start troubleshooting.
    This is what I received from PCM
    DTC Trouble code 174 description is: Adaptive-Learn Gasoline Bank 2 High
    This means the 02 sensor on the EVEN Bank side of the engine
    (cylinders 2,4,6,8)have a Lean fuel emmissons reading or injectors not
    opening properly to spray the correct amount of fuel on this bank.
    It could mean one or more injectors on this bank need service or cleaning.
