Hey guys, about to install some sea Deck in my 2013 230 and need some guidance from those who have done this before.
-2013 230
-Floor Only, Replacing Snap In Carpet
-recommendations for filling in exposed snap holes?
-Should I go through seadek direct, or find a dealer?
-ok to install on top of raised grid non slip surface?
-i received a PDF pattern from seadek for 2010 230. Will this be the same for a 2013?
-the dimensions they have on there go beyond the raised non slip grid, so a bit of a lip transition that will be under the edges of the seadek. Does this work ok or does the seadek need to be slightly smaller than the limits of the non slip grid?
Thanks for the help!
Sent from my Pixel 2 using PLT Nautique mobile app
-2013 230
