2003 Nautique 216 PCM Excalibur 330 oil Cooler Hose Length
  • dkimball
    • Aug 2008
    • 125
    My boat is currently in storage (not accessible storage) and I am trying to order some parts so I can be ready to go when I pull it out for the year. I noticed my 1 and 1/4" hose running from my transmission oil cooler to the raw water pump was starting to crack so I am going to replace it. Can anyone tell me the approximate length needed? It is sold by the foot and I want to make sure I order enough. It is number 22 on the parts diagram for a 2003 excalibur 330 direct drive attached.
  • Quinner
    • 2246
    • Correct Crafts
    Unless you are willing to buy an extra foot or two I would measure your own boat to ensure you get exactly what you need. That hose is pretty stout so it's not likely it will fail catastrophically, next time at the boat measure and order exactly what you have.
    • dkimball
      • Aug 2008
      • 125
      Its only around $6 a foot so I am not overly concerned with an extra foot or two. I was just trying to get it done before launching it for the year because once it is in and on the lift up at our cabin it is a lot harder to work on away from home. I planned on measuring it in the fall and forgot and can wait and measure it this year I was just wondering if anyone knew the length off the top of their head. Thanks.
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        Call White Lake Marine at 910 862 3688 and one of the techs there can tell you for sure.
        -Charles
