Hello all, new to the forums. I have 2000 Pro Air Nautique that I recently purchased with the 275HP PCM 5.0 HO motor. It has a knob on the front section that I do not know what it does. Also there are 2 wires sticking out (black & white in pictures) that look like they are supposed go into the wiring harness. When I reconnect the wires to where they look like they should go, the knob seizes up, when I disconnected, the knob is loose. This is with the battery (good) currently connected. So below are my questions.
1. What is this knob?
2. Are the loose wires supposed to be connected?
Currently the motor does not run (suspect fuel delivery issue), however I will be making another post regarding this later.
Thanks for all of the help!
- David
- David
