I have a 2001 Super Air and both the tach and speedo gauges power on but the displays do not fully illuminate and therefore I can not make out the rpms, hours, or speed. Is anyone else experiencing similar problems?
Tags: None
Speedo and Tach Problems
Exactly the same issue happened on my 2001 SAN, I take out both guage to my lab,I opened the case and check the PCB ,found the problem caused by water leaking, rust appear on the PCB,I clean it and spray a layer protector, install back, it works fine until now,
recently, the display can't see after rainning day, when sunshine few days,it appear agin and works fine, I'm thinking to change it. If Faria will send me new one by free ,I'll extreme happy.
RE: Speedo and Tach Problems
There are alot of threads about the teleflex guage problems. Do a search or save time and have your dealer order you a Faria upgrade around 250.00.Nautiqueless in San Diego
