Getting more power out of GT40 | 1998 Super Sport Nautique
  • Jousicastillo
    • Jul 2016
    • 13
    • Paraguay
    • 1989 ski nautique 2001 and 1998 super sport
    Hi Guys,
    I am riding (Wakeboard) an absolutely slammed 1998 210 (Super Sport), with about 4200 lbs in ballast ( displacing a total of about 8000 lbs, hull weight included).
    Engine is working quite hard, so I was wondering what upgrades or preventive measures could be taken, to avoid either block, cylinder, valve breakage, without having
    to sacrifice weight ballast (wake is absolutely amazing at 23.9mph and a 77.5 feet rope).
    I am doing oil changes every 50 hours (Valvoline Racing VR1), trans every 100 hrs (Dexron/Mercon III) and V drive oil every 500 hrs (non detergent 30W straight).
    Engine has around 1000 hours.
    Thanks!!
  • Dgee
    • Jul 2016
    • 137
    • Portland, OR
    • 1999 SAN
    What prop are you currently running? Best bang for the buck would be an upgraded prop.
    • Tryathlete
      • Feb 2015
      • 217
      • Lake Villa, IL
      • 1996 Nautique Super Sport
      Agree on finding the right prop. Call Acme and see what will get you a good match of rpm and your 23.9 mph. I’m not sure but I’m guessing you should aim for under 4500 rpm (I’d think 4000) would be a reasonable goal.
      • Jousicastillo
        • Jul 2016
        • 13
        • Paraguay
        I am running an Acme 1578 prop. Running a bit under 4000 rpm with the aforementioned weight
        • Infinity
          • Sep 2017
          • 730
          • Lake Norman - Denver, NC
          • 2014 SV244 w/ ZR409
          Your probably ok then, at least in my manual, it says to avoid running for extended periods over 4000rpm. Still, a more hardcore prop could bring down rpm's which would save you some gas and wear on engine. ACME can tell you.....and from what I have found, Nettles Props in TX have the best prices
          • TRIP
            • 433
            • Costa Rica
            • 1997 Nautique Super Sport
            I just want to see that wake! Any pics or better video?!
            • Jousicastillo
              • Jul 2016
              • 13
              • Paraguay
              Here you go
              • Jousicastillo
                • Jul 2016
                • 13
                • Paraguay
                great info! thanks!!
                • funkster
                  • Mar 2011
                  • 199
                  • Washington,state
                  • 87' Ski Nautique(sold) :( & 98' Super Sport
                  Wake looks awesome and nice riding. I would like to here where you have your weight. I have the same boat 98' SS and I'm running 910's in the rear lockers(about 3/4 full w/ wakeboarding) and a 580 in the ski locker and about 300 of sand under the bow seats for a estimated 2,500lbs. She takes forever to get on plane. How long does it take you to get on plane with the Acme 1578?
                  • Jousicastillo
                    • Jul 2016
                    • 13
                    • Paraguay
                    On a old gen 210 nautique, weight placing acts as follows:
                    back: makes wake peakier and vert
                    middle: makes wake bigger and meatier
                    front: gives wake some transition and helps maintain wake shape at lower speeds
                    Taking that into account, the setup I use is the following:
                    two 700lbs bags in the back (1400lbs) - 34% of total weight
                    one 580lbs bag in the ski locker and a 1100lbs bag on top of it - 42% of total weight
                    one triangle of 1000lbs in the bow - 24% of total weight
                    Also, i usually I have one or two people in the boat (driver included).
                    speed is 23.9 mph and rope 77.5 feet.
                    wake cleans nicely, transition is comfortable and the wake has a very manageable kick to it.
                    boat also planes in about 15-20 seconds or so. Needless to say, one should be carefull when
                    stopping ( I use the factory bow cover just in case).
                    having recently wakeboarded on a 2018 Centurion Ri237, I would say this setup is a smaller
                    version of that wake, with less transition.
                    Finally, based on what you wrote, i think you are missing some middle and bow weight!
                    • Infinity
                      • Sep 2017
                      • 730
                      Very nice riding!
                      • Jousicastillo
                        • Jul 2016
                        • 13
                        • Paraguay
                        Very nice riding!
                        thank you!
