Has anyone install the upgrade from rpm cruise to wakeboard pro themselves. If so wandering how hard it was. I know the servo stays the same and you have to cut the hole in the hull for the paddle wheel and also change the control module and control display. The hole in the hull is the only part i'm really worried about.
Tags: None
RE: perfect pass upgrade
Very easy. You can use the paddle wheel that came with your boat (if it is a newer Nautique). The only thing you loose is the lake water temperature feed. The new paddle wheel is half inch smaller in diameter then the one that is in your boat. If you don’t have a paddle wheel look here:
http://www.wakesiderides.com/viewArticle.php?id=223sigpic
Re: RE: perfect pass upgrade
Originally posted by EchoLodgeVery easy. You can use the paddle wheel that came with your boat (if it is a newer Nautique). The only thing you loose is the lake water temperature feed. The new paddle wheel is half inch smaller in diameter then the one that is in your boat. If you don’t have a paddle wheel look here:
PP
Opps... The new PP paddle wheel is larger then the paddle wheel that came on my friend's 01 Air Nautique. The PP cruise that came on his boat had a paddle wheel. Perfect Pass sold me the parts I need to upgrade his cruise to Wakeboard Pro.
His boat has a water temp guage made by Hummingbird. Takes temp from a sensor in a t fitting from the fresh water intake. His pp cruise wheel did not have the lake temp feed for the Wakeboard Pro input.sigpic
