Best way to polish/protect tower
  • Infinity
    • Sep 2017
    • 730
    • Lake Norman - Denver, NC
    • 2014 SV244 w/ ZR409
    I think my tower is anodized, not painted... but that said, what is best way to clean and shine it up pretty without removing finish?
    Then I assume to protect, I can wax with Collonite paste wax that I use for hull?
    Sent from my SM-G930V using Tapatalk
  • homer12
    • Feb 2016
    • 584
    • Indianapolis, IN
    • 2004 SV211 TE
    I don't have the exact answer to your question, but I've used this - Klasse All in One - on auto paint before with pretty awesome results before the wax. You can use it on any shiny surface basically.
    http://klasseusa.com/kalsse-all-in-one.html
    • srock
      • Oct 2008
      • 1066
      If its black and you want to clean it up, home depot appliance epoxy black will stick to it with a nice finish. If you leave it in place be forewarned that the over spray will travel and stick to everything in its path. Used it to touch up my saltwater boat powdercoated marlin tower. Lasted 8 years until I sold the boat.
      • Infinity
        • Sep 2017
        • 730
        I did not want to paint it since it still looks really good, just had water spots, etc....wanted to clean it up really good and seal it. I ended up using TR3 which worked really good and has a resin finish (works good on auto paint and gelcoat....supposed to remove water spots and light oxidation....and it does)....and then I waxed with Collonite. Turned out really nice!
