I need someone's help on advice for what to check after installing my Blue Sea Add-a-battery system (http://assets.bluesea.com/files/reso.../990310020.pdf). I have a 2014 Sport 200 Team Edition (with Linc screen). It only came with 1 battery and was located in the port v-drive locker. There was/is a main kill switch by the driver's feet. I decided to add a second battery using the Blue Sea system with Automatic Relay included. My Problem: When I turn the main switch to the 'On' position I do not get any power at my screen nor do my amp lights turn on, I do however hear my fuel pump cycle. Here is how I hooked up the system:
**The other thing that is weird is the Blue Sea automatic relay light is on (no flashing), even though the main switch is off. The on light according to the directions means the batteries are charging as if the motor was running and the relay is engaged. This does not make any sense either.
- I replaced the main kill switch that had On / Off only with the red kill switch that came with the Blue Sea System (Off - On - Combine Batteries), and kept it located in the same position as the stock switch by the driver's feet.
- There were 2 large power cables coming from the back of the boat that were connected to the stock power switch. I assumed these were for the starter and starter battery (original battery). I therefore hooked these up to the appropriate studs on Bank 2 of the New switch (see link).
- There was 1 other large power cable that was coming from a distribution fuse block both located near the driver's feet. I assumed this was the power for the House electronics, so I hooked this up to Bank 1 of the new switch.
- I routed the power from my amps to Bank 1 of the new switch.
- I then routed the positive side of the New 2nd battery to the other stud on Bank 1 of the new switch. By doing this I figured I had separated the house electronics from the starter.
- As for the Grounds: I did not change any grounds from the house electronics, but it looks they were connected to 2 different negative bus bars which eventually lead back to the block on the engine. The original battery (now the starter battery) ground was also hooked to the engine block. The new battery (now the house battery) has the amplifier ground hooked to it, but it DOES NOT ground to the engine block (could this be my problem?).
- As for the Blue Sea automatic relay, I have one positive cable going to the starter battery and one positive cable going to the house battery. The small ground wire on the automatic relay goes to the ground on the starter battery.
- It's probably worth noting that I used the m-series switch (300A continuous rating) instead of the e-series switch (350A continuous rating) because the m-series was the same size as the stock switch and fit into the mounting hole perfectly. I figured this would not be an issue because it was approved for stock and amperage rating was close to the same. I DID keep the ACR switch for 120A (e-series package).
