high oil pressure
  • optie2
    • Apr 2018
    • 14
    • netherlands
    high oil pressure
    we haven ski nautique 1993 white a ford 351 5,8
    we have high oil pressure 80psi
    we haven changed the oil pomp but the oil pressure is stil 80 psi bij 600rpm
    what can be the problem?
    greatz bas
  • optie2
    • Apr 2018
    • 14
    • netherlands
    is it possible that a crank bearing spins around so the oil hole is close?
    • srock
      • Oct 2008
      • 1066
      At idle?
      • optie2
        • Apr 2018
        • 14
        • netherlands
        Is runs 75 psi at 600rpm
        at 1500 rpm and more iT is 80psi
        we haven put in a new oilpomp new oil new oil filter
        • Wayward
          • Apr 2013
          • 424
          • Northeast
          • 2022 XStar
          Have you checked it on a manual gauge? The Electric sending unit could be bad.......
          other than that, it could be the oil pump relief valve. But you say you changed the pump? Is it reading the same hot or cold?
          • optie2
            • Apr 2018
            • 14
            • netherlands
            We have renewd te oilpressure sensor
            the pressure-cooker is high hot or cold is the same
            • optie2
              • Apr 2018
              • 14
              • netherlands
              Sorry not a cooker
              • optie2
                • Apr 2018
                • 14
                • netherlands
                We have but on a Manuel pressure unit a than is the pressure stil 80psi
                we have done everything
                • funkster
                  • Mar 2011
                  • 199
                  • Washington,state
                  • 87' Ski Nautique(sold) :( & 98' Super Sport
                  Do you have any oil coming out of the dipstick?
                  • optie2
                    • Apr 2018
                    • 14
                    • netherlands
                    No oil coming out
                    • rcsmith727
                      • Apr 2017
                      • 49
                      • Denver, CO
                      • 1995 Nautique Super Sport
                      what oil are you using?
                      • funkster
                        • Mar 2011
                        • 199
                        • Washington,state
                        Originally posted by optie2
                        No oil coming out
                        I would then check the oil pump pressure relief valve. Make sure you're replacing parts with OEM parts.
                        Also check the PCV and make sure it's not gummed up and is moving freely.
                        Did you replace the oil filter with the proper OEM filter?
                        Did this just happen out of the blue?
                        • optie2
                          • Apr 2018
                          • 14
                          • netherlands
                          hello Funkster
                          it happen out of the bleu on the end of last somer
                          last week we put a new oilpomp in it...the pressusre relief is in the pomp stil 80psi
                          oil filter pcm
                          wat do you mean bij PCV?
                          • funkster
                            • Mar 2011
                            • 199
                            • Washington,state
                            The PCV or possible crankcase allows the blow-by gases, consisting of the combustion products and the oil vapors, to be vented. It's located on the valve cover. I had a high oil reading on my old 87' and a clogged PCV valve was the culprit. Might be worth a look. You can take it off of the valve cover, and out of the carburetor/throttle body hose and clean it out with carburetor cleaner and compressed air. The little ball inside should rattle freely.
                            • Michigan210
                              • Jan 2018
                              • 11
                              • MI
                              • 2018 Super Air Nautique 210 Sold: 2011 Axis A22 Sold: 1994 Ski Nautique
                              I'm willing to bet you have too much oil in the engine, happened to me on my old Axis A22. Drain about a quart and try it again.
