Preventing Engine Corrosion
  • Nautique Fan
    • May 2016
    • 136
    • Utah
    • 2007 SANTE 236 ZR6
    I have a 2007 236 and in the engine manual it states:
    Protect engine finish from corrosion by periodically spraying the engine exterior finish with a rust preventative oil (such as WD-40).
    What should I spray and what should I avoid spraying? Is WD-40 the best product to use?
  • Infinity
    • Sep 2017
    • 730
    • Lake Norman - Denver, NC
    • 2014 SV244 w/ ZR409
    Interested in this as well, was just reading that myself in my manual the other night and saw something called "Fluid Film".....for metal parts to prevent corrosion/rust. Says its a penetrant and lubricant...protects all metals, lanolin based, no solvents, non-toxic/hazardous. Anyone heard of this or used something else besides WD-40?
    • neirbot
      • Jul 2015
      • 94
      • DFW
      • 2016 230
      Fluid Film would be perfect. It's a staple in my garage.
      Sent from my Pixel 2 using Tapatalk
      • trip33
        • Nov 2010
        • 248
        • Odessa, FL
        Corrosion X
        • Nautique Fan
          • May 2016
          • 136
          • Utah
          What exactly do you put it on? Everything?
          • 2001SAN
            • Apr 2012
            • 203
            • Ireland
            • 2001 Super Air Nautique 210, 1989 Fairline Corniche 31
            I use acf-50. Pretty thick stuff compared to wd. I spray exposed surfaces.
            D.
            • Evening Shade
              • Apr 2015
              • 1295
              I read a great article on the net about the best corrosion inhibitors. They did an independent study comparing about 40 different products. The study was very well done and without going into details Hornady One Shot and WD-40 Specialist Long Term Corrosion Inhibitor came out on top as 2 of the best corrosion inhibitors.
              Hornady One Shot is made for guns and thus is a little more pricey. WD-40 Specialist Long Term Corrosion Inhibitor would be my top choice. Spray it on all exposed metal including the engine mounts.
              • srock
                • Oct 2008
                • 1069
                I hit my motocross bike exhaust as well. It makes the bike faster.
                • Nautique Fan
                  • May 2016
                  • 136
                  • Utah
                  Just a quick follow up question. Can you spray engine parts that get hot? And what about the exhaust manifolds?
                  • Evening Shade
                    • Apr 2015
                    • 1295
                    Yes you can spray the parts that get hot.
                    • charlesml3
                      • Jan 2008
                      • 2455
                      • Lake Gaston, NC
                      • 2022 G23
                      Agreed. Those parts are likely to smoke and stink a bit when they first burn off the protectant, so don't be surprised if you see that.
                      The best thing anyone can do to prevent corrosion is to GET THE WATER OUT. If there's water left in the bilge, it evaporates on hot days. Since it has nowhere to go, it condenses back on to the engine, wiring, etc. This is where most problems start. If you can leave the hatch open a bit or Shop-Vac the water out of the bilge, you'll be miles ahead of preventing corrosion.
                      -Charles
                      • Nautique Fan
                        • May 2016
                        • 136
                        • Utah
                        Thanks for the advise. The bilge is kept dry since we trailer to the lake and pull the plug each time so it drains well. I also open everything up after each use to dry everything out. Spraying the engine with wd-40 sounds like an end of season task. I appreciate all the input.
                        • charlesml3
                          • Jan 2008
                          • 2455
                          • Lake Gaston, NC
                          • 2022 G23
                          Oh you'll be just fine then. You're doing everything you should be doing to get water out of the boat. Opening up the compartments is a HUGE help. A lot of people get into mildew problems from covering a wet boat.
                          -Charles
                          • Infinity
                            • Sep 2017
                            • 730
                            I always put in box fan in bilge overnight too after weekend to get everything bone dry....also use commercial air mover in boat overnight to circulate air, dry out everything, etc. I do that whether I cover or not. Works just as well with cover on
                            • charlesml3
                              • Jan 2008
                              • 2455
                              • Lake Gaston, NC
                              • 2022 G23
                              Holy cow, man. You'll never have any trouble with mildew or corrosion with all that. I bet that vinyl will still look new in 10 years.
