Noob Maintenance Questions
  • Joshua J Rowe
    • Jan 2017
    • 85
    • Columbus Ohio
    • 1999 Air Nautique GT-40
    2 seasons and less than 100 hours on a raw water impeller pushing it?
    Anyone have any good tricks for changing the trans fluid at home without making a mess?
  • Viper_Freak1
    • Aug 2017
    • 19
    • Nowhere
    • 2001 Super Air Nautique
    Just changed trans fluid on my boat (2001 SAN 210) and used an oil extractor pump. No mess at all. Got the pump off Amazon for around $30 I think.
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      Change the impeller at the beginning of every season, regardless of hours.
      • Joshua J Rowe
        • Jan 2017
        • 85
        • Columbus Ohio
        Are you saying you used that to draw the fluid out the fill/dipstick hole?
        • Joshua J Rowe
          • Jan 2017
          • 85
          • Columbus Ohio
          Will do, thanks.
          We used it quite a bit last year until we broke the tower. Would have easily done 50+ hours last season if that had not happened. Is the impeller reliable for than much use?
          • charlesml3
            • Jan 2008
            • 2454
            • Lake Gaston, NC
            • 2022 G23
            Originally posted by Joshua J Rowe View Post
            Will do, thanks.
            Sure. They usually go bad over the winter when they sit. That's why I was saying to replace it every spring. I've done that for nearly 20 years now and never had one fail.
            -Charles
            • Joshua J Rowe
              • Jan 2017
              • 85
              • Columbus Ohio
              -Charles
              Exactly why I ask what seem to be simple questions. That is a very valuable detail. Appreciate the experienced perspective!
              On a side note, I have been changing my engine oil in the spring instead of prior to storage in the fall. Any opinion on that?
              • Viper_Freak1
                • Aug 2017
                • 19
                • Nowhere
                Yep that’s exactly what I did
                • charlesml3
                  • Jan 2008
                  • 2454
                  • Lake Gaston, NC
                  • 2022 G23
                  This isn't the best way to do this. On the GT-40, there's a hose designed to drain the oil. It'll be clipped on the left side of the engine near the alternator. Take the brass cap off and insert your oil extractor tube into this instead of the dipstick tube.
                  The problem with the dipstick tube is where it attaches down at the casing. It'll often have a sharp edge there and the extractor tube can get stuck on that. Then you're in a bit of a pickle. It happened to my neighbor on his Mastercraft. It's better to use the built-in oil drain hose.
                  Plus, the oil drain hose is at the very lowest part of the oil pan and you'll end up getting more of the old oil out that way.
                  Here's a good discussion on this: https://www.planetnautique.com/vb5/f...oil-drain-hose
                  -Charles
                  • Viper_Freak1
                    • Aug 2017
                    • 19
                    • Nowhere
                    -Charles
                    I was referring to the transmission and v drive for using the extractor pump. For the engine oil I use the drain hose. But for the transmission and v drive, it’s just too much of an *** pain to not use the pump unless there’s an easier way that I don’t know about.
                    • Joshua J Rowe
                      • Jan 2017
                      • 85
                      • Columbus Ohio
                      -Charles
                      With respect to the transmission,
                      I do not see how it was intended to have the fluid changed without one of those exchanger machines. Drawing a few quarts out and replacing with new sounds like the only option that I can do at home. Done that with steering pumps before.
                      • Viper_Freak1
                        • Aug 2017
                        • 19
                        • Nowhere
                        Another question, is there an easier way to get the strainer out of the v drive unit? The manual says that the strainer should be clean and magnetic plugs cleaned off as well. But after seeing how difficult it would be to get my hands down there I decided the **** with it. Anybody have any ideas on this or is it really even necessary?
