Hey all. I have a heater in my 2003 SANTE that appears to be set up the way it was from the factory, with the water return going back into the pump. I had a y-pipe in my old boat and I really felt like it helped give better heat at idle, so I bought one for this boat. I'm curious about the construction, though - there is only a tiny hole between the "Y" and the larger pipe itself - it's nowhere near the full 5/8" or so diameter of the smaller Y piece.
Have others used this same piece with good results? I'm tempted to drill it out larger before installing it. But I'm also thinking it would be easier to try it as-is, because it would be much harder to fill in than to drill out later. But why would that hole be so small in the first place? Edit - I do know it can be hard to get the system primed (it can suck air from the heater line) at initial startup. But if you have the system filled with antifreeze, and/or prime it with water, I don't see a downside to the y-pipe.
