Gauge not working
  • Kdmann64
    • May 2018
    • 2
    • Madison GA
    • 2006 super air nautique 226
    Gauge not working
    Just bought 06 226
    speedo gauge doesn’t ’work ballast gauge doesn’t work
    fuel gauge and one other I can’t remember. Where do buy new guages and how hard to fix ?
  • Kdmann64
    • May 2018
    • 2
    • Madison GA
    Gauges
    • Infinity
      • Sep 2017
      • 730
      • Lake Norman - Denver, NC
      • 2014 SV244 w/ ZR409
      Check NautiqueParts.com
      You get discount as member here too. PND
      • shonuff
        • Sep 2010
        • 157
        • Atlanta, GA
        • '05 SANTE
        Before you go spending money on new gauges, you need to determine if your gateway box is failing or not. If it's the gateway box, you're SOL since it's discontinued and Faria/Nautique don't stock/sell them anymore. Your only option would be to do the Faria analog conversion kit to replace all of the gauges.
        I just lost my tachometer, temp, battery and oil pressure gauges so I'm going through a similar situation right now. I have the conversion kit on order from Nautique Parts.
        PS- I don't think the ballast gauges are controlled through the gateway box. If that gauge is dead, it could be the sending unit in the tank.
        2005 SANTE
