2007 SAN 220 depth gauge not working / replacing thru hull transducer
  • Rjheibel
    • Apr 2018
    • 14
    • NC
    • SANTE 2007 220
    I have a new to me 2007 220 with a depth guage that's not reading, but air and water temp are still working on same guage. Im assuming its the transducer. Anyone have this problem and able to fix by replacing transducer? Any tips for its replacment?
  • ally505
    • Feb 2012
    • 178
    • Somewhere cold and wet
    • 2008 super air nautique 210, zr6.
    The depth gauge is a little flaky on my 08. It works if the boat is stationary or idling only. Before you go ahead and change it, make sure it definitely isn’t working at any speed.
    • Rjheibel
      • Apr 2018
      • 14
      • NC
      • SANTE 2007 220
      Unfortunately the depth never reads for me, idle or moving.
      • H2O
        • Jul 2006
        • 247
        I did a write-up 5-18-12, in the DIY section of this forum. It is exactly what you need. Titled ,"Built-in Depth Finder..."
        • Rjheibel
          • Apr 2018
          • 14
          • NC
          • SANTE 2007 220
          H20, thanks for the write up.
          Just to verify, this connector is for the 07 220? Also, the Airmar transducer i bought from nautiqueparts (CS-P692) has 2 insulated wires and a common non-insulated wire. The DT06-2S only has 2 connectors. Do you not need to connect the non-insulated wire? Last question, should i use BoatLife Caulk or Sealent?
          • H2O
            • Jul 2006
            • 247
            This was on a 2007 210. Transducer only had 2 wires as I recall. Same as original. BoatLife is recommended.
            • Rjheibel
              • Apr 2018
              • 14
              • NC
              • SANTE 2007 220
              Unfortunately the new transducer didnt seem to fix it. Still reading - - -. Anything else i could do? All other guages work including the air and temp on the spedometer where the depth guage reads. If all else fails i guess ill just install a separate depth guage.
              • H2O
                • Jul 2006
                • 247
                Sounds like a problem with the electrical wiring/connections. Did the original transducer you removed have two or three wires?
                • H2O
                  • Jul 2006
                  • 247
                  My foggy memory seems to recall that the bare wire had to be combined with one (which one?) of the insulated wires. I recall that I just copied the old transducer wiring.
                  • Rjheibel
                    • Apr 2018
                    • 14
                    • NC
                    • SANTE 2007 220
                    When i pulled it, they had one insulated wire and one uninsulated wire connected to the plug. Problem is im afraid that the pevious owners tried to fix at some time so i dont knownif i can trust that. Guess i can try to combine the uninsulated wire before i go another route. Does the water temp get measured by the transducer as well. Because that works??
                    • H2O
                      • Jul 2006
                      • 247
                      Found my notes on the install. Airmar Transducer # 31-699-1-01. The Blue wire=Signal. Black+Silver (bare) wires twisted together=Ground. Insert plug into P13 port in Gateway Box. Blue closest to P15 port, Black/Silver closest to P12 port. Should work perfectly.
                      • Rjheibel
                        • Apr 2018
                        • 14
                        • NC
                        • SANTE 2007 220
                        Thanks for looking that up! Ill try it out tomorrow.
                        • firemangreg
                          • Aug 2010
                          • 13
                          • Portland, OR
                          • 2008 SAN 230TE 2005 SAN 210TE 1988 Supra Comp
                          Did the transducer ever work for you? My 2008 is doing the same thing. Just flashes a dash in the feet. Started out intermittently working, now never shows. Water temp registers fine. I’m wondering if it’s the same issue as the fuel gauge through the gateway box, which is why I was wondering if you ever got the new transducer working.
