2004 211SV Team Edition Low Voltage Alarm
  • bbeyer14
    • Aug 2006
    • 6
    Hi, I have a 2004 211 with a Voltage issue. First it is giving an intermittent low voltage alarm. I have checked the output of the alternator and it is at 14V constant. Voltage will go low for a while then bounce back to 13.8 on the gauge then it will drop again. There are also 2 brand new batteries in the boat both reading good. Bad Gauge? Any help would be great.
  • hyperlitep
    • Sep 2012
    • 82
    • Wenatchee WA
    • 2010 210 TE Previous boats:2005 Ski 206 LE 1991 American Skier
    Following. I think I’m having the same issue as you. I think it’s the wire size from the battery to the pme box.
    • bbeyer14
      • Aug 2006
      • 6
      Thanks, Not sure what the PME box is. Is that where the main ECM is located? I have a perko switch with 2 batteries and the cable is a pretty large gauge. After digging around last night too I read it could be a grounding issue also. Will try to dig into it this weekend.
      • hyperlitep
        • Sep 2012
        • 82
        • Wenatchee WA
        Pme box is the breaker box under the dash. Let me know what you come up with! I’ll do the same!
        • peteSki
          • Mar 2005
          • 232
          • Ottawa, On, Canada
          • 2005 Sport Nautique 216 Previous: 1997 Ski Nautique
          I had a similar issue on my 2005 Sport 216. After some reading here found that the wires to the breaker box were undersized for that era of boats, so I replaced both the positive and negative ones with larger new wires and that solved my issue.
          • hyperlitep
            • Sep 2012
            • 82
            • Wenatchee WA
            What gauge wire did you use?
            • peteSki
              • Mar 2005
              • 232
              I used 8ga wire. The positive wire went from battery to the master on/off switch and then to the breaker box, and the ground went right to the breaker box. I also installed a relay for the perfect pass power and ran new wires (16ga) for the main power as PP seems to be pretty power hungry. After that I saw less than a 1V drop between alternator/battery and the volt gauge on the dash and the PP volt display.... so no more low voltage alarms.
              • hyperlitep
                • Sep 2012
                • 82
                • Wenatchee WA
                Thanks!
                • Polidori
                  • Jun 2017
                  • 107
                  • Lake Anna
                  • Alexandria, VA
                  • '05 SV211
                  My ‘05 SV211 was giving me a low voltage warning and the shop determined that it was a faulty alternator. Your results may vary.
