Fuel Smell and slow to crank
  • NautiqueNutt
    • Aug 2004
    • 17
    • Mississippi
    I have a 99 PAN with GT40 Fuel Injected. It runs fine but after it gets hot and sits in the water for more than a minute or two it is sometimes slow to crank and then I smell fuel after it does crank. I have changed the plugs out and don't know what to check next. It has 710 hours. Since I smell fuel I assume that this is excess coming from the exhaust. It must be an ignition problem? How do I troubleshoot this?
  • Onthewater
    • 695
    • Near the cheddar curtain
    RE: Fuel Smell and slow to crank
    the fuel smell might also indicate a fuel problem, i'd check that out asap.
    I don\'t care.
    • surroundsound64
      • Jul 2005
      • 2147
      • Longview, TX
      • 2018 230 1981 Ski Nautique
      I doubt the 2 problems are related. Run the blower and check the battery. It may be old, it may be bad. Check and make sure there are no loose or corroded connections.
      2018 SAN 230
      1981 Ski Nautique
      Sold - 2011 Sport 200V
      Sold - 2000 SAN
