My part comes in this am......I will look at the connections later today.....I did not look at them. I will definitely do so before I replace part. Great info! thank you
BAMMMMMMMM.........that was it folks.......Rotor and Cap........Ran like a champ for 2 straight hours yesterday! Fingers crossed.......thanks again!
Not trying to be Cheesy, but this sight is fantastic for troubleshooting! it sure will save you a lot of money in the long run. Thanks again everyone for the comments and suggestions!
Dave
interesting......yesterday........volts and temp were on........then 30 min later the rest came on...........mph and rpm act weird.....but I assume its the tubing set up. Do you trust the LED read our from the faira gauges? Seem to be close in numbers when dash kicks on. Was thinking about relying on those instead of trying to fix. Thoughts?
When I bought the boat....he said he had a impeller leak.....fixed it on the lake with JW Weld. It was pouring water on the sensor....which is 2 to 3" away from pump. I saw this...took off JW...replaced impeller and the seal. Then took the tape off the sensor that he put on. Now that the boat is running.....this has been fine
I find the digital gauges to be accurate. It's a shame that Faria stopped making the gateway. Maybe it would be a good idea to check the connections at the gateway? Maybe even pull out the connector, spray some electrical cleaner on it, and put it back. I might try that this weekend!2004 Super Air Nautique 210 Team Edition
1994 Ski Nautique (sold)
1979 Ski Nautique (sold)
