DampRid Pails
  • imhoff
    • Jun 2016
    • 108
    • New Fairfield, CT
    • 2015 G23 450
    I use two small pails of damprid in my front hatches (nestled into the back-inside corners), and then have bags hanging next to the garbage pail and from each of the overflow connections in the rear hatches and it does wonders during the season. I think it makes a huge difference...
    • GMLIII
      • May 2013
      • 2797
      Based on Imhoff’’s above response, I changed my Damprid placements and container types. 2 Damprid pals stern lockers, 3 hanging Damprids midship, and 2 low profile Damprid containers in bow area . This should help with moisture during winter layup
      • scottb7
        • Aug 2011
        • 2198
        • Carson City, Nevada
        Question. After the offseason of use, what do you do with the partially filled containers of damprid in the spring. I got 2 pails and looks like maybe 1/3 full of water-ish stuff. I put the tops back on. Do I just save them for next winter? The tops have some kind of membrane so I assume you can't pour anything out or clean, can you?
        • charlesml3
          • Jan 2008
          • 2454
          • Lake Gaston, NC
          • 2022 G23
          Just put the lid back on and keep them for next year. They're fine. You only need to replace them when they're full of water.
          • scottb7
            • Aug 2011
            • 2198
            Thanks! P.S. The boat did seem less humid inside. Thanks again.
            • GMLIII
              • May 2013
              • 2797
              #21
              I just leave mine in my boat until they are completely saturated and are at the fill line . I leave them in my boat 365 days 24/7.
