I went to do the first start up for the year. Boat will not start. I have found that no spark at the plugs. No spark at the coil wire. Have tried a nown good coil. No change. Kill switch is by-passed. Boat ran great at the end of the year. Batteries are charged. Thanks in advance for any ideas.
Tags: None
I would agree with the above - does it turn over? and how did you determine no spark? Silly question - but boat is in neutral right? Throttle could have been bumped out of place, and neutral safety switch is good?
Yes the engine would turn over..sounded good. I checked for spark at the plug with a spark tester. Also checked fuel pressure. Problem ended up being weak batteries.. Voltage droping below 10 volts.. Replaced both batteries problem solved. Thanks
Sent from my VK810 4G using PLT Nautique mobile app
