2001 SAN210 Issues
  • Codywb01
    • Mar 2018
    • 35
    • Mercer, PA
    • 2001 SAN 210 1992 Ski Nautique 196
    2001 SAN210 Issues
    Was cruising down the river this past weekend and was doing about 30 mph when there was a loud stutter in the engine. It shook the entire boat for a few seconds before I knocked it out of gear.
    I put it in reverse for a minute and continued down the river. Any ideas as to what this would be?
    I also am having issues with water getting into the bow. I think the only explanation I can be is the new puppy pump system is overflowing into the bottom of the hull and the bilge is just not pumping it out fast enough.
    Please let me know if anyone else has had the same issues and any solutions you’ve found.
    Thank you
  • Rusty Barras
    • Dec 2014
    • 180
    • new orleans
    • i own a 2001 super air nautique
    I think when the motor goes into "limp mode" it'll do that. It's only happened once to me when the temperature got high from a bad impeller. my best guess.
    • Codywb01
      • Mar 2018
      • 35
      • Mercer, PA
      My temp was at 160 and was not running hot. I don’t think that’s the issue but still a good starting point. I’ll check that this week. Thanks!
      • functionoverfashion
        • Jun 2017
        • 509
        • New Hampshire
        • 2003 SANTE
        From my reading of the issue you had while running on a river: the boat shook, you stopped, put it in reverse, then when you continued the shaking was gone? That sounds to me like you picked up something with the prop- like a part of a towel or something - that then came off when you put it in reverse. Just a thought.
        • charlesml3
          • Jan 2008
          • 2454
          • Lake Gaston, NC
          • 2022 G23
          Agreed. Could have been a length of black rope that you just didn't see. Lots of possibilities.
          -Charles
          • wakejunky
            • 679
            • Ca
            • 2003 SAN
            I know when there is floating wood on my local lake, I'll occasionally impale a small piece of wood that'll stick to the propellor. If I bring it off plane, reverse and then go on my merry way, that'll release the piece of wood. Usually nothing happens to the propellor but, I'd notice it when I got back on plane.
            • Codywb01
              • Mar 2018
              • 35
              • Mercer, PA
              That’s what I thought as well. It would make sense if it was a towel or a rope as I didn’t hear a thud like I hit anything. The weird thing was that it did the same thing two days before. And I like to think I keep a pretty decent eye on what’s in front of me. Anyone have any ideas of a mechanical issue that would make this occur?
