Defeating a broken battery selector
  • trip33
    • Nov 2010
    • 248
    • Odessa, FL
    Just in case your battery selector ever splits apart and does not make contact, here is how you can bypass it. Especially when it happens on a holiday (ask me how I know).
    step 1 - get access to the back of the selector
    step 2 - move one of the other batteries to the common post (see pics)
    step 3 - enjoy the rest of your day having only been slightly delayed
    I realize this is some basic stuff for many of you, but if I help one person save their weekend then it is worth it.
    Pic on left is the before
    pic on right is the after
ID:	557018 Click image for larger version
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    Holy crap.
    WARNING: you can burn your boat down to the water line if you mess this ^^^ up. Let those terminals rotate a hair because the cheap cables are too stiff and make contact and watch Satan come alive in your G.
    Nautique leadership should fix this, 3-4 years of this now?
    coming from a guy who was broke down on the water twice by this same issue and had to pay out of pocket to repair both times. Thanks Chessie Marine for not returning calls, great way to honor warranties!
    Bill- here’s your freebie. The problem isn’t the switches, tell your team to source quality flexible power and ground cables. They won’t rip the Perkos in half.
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • Evening Shade
      • Apr 2015
      • 1295
      I just had the exact same thing happen this past weekend. Luckily West Marine was open till 8pm on Saturday so I picked up a new switch. Installed it Sunday morning and was back in business. Marine Max is going to reimburse me for the cost of the part.
      I agree with Ryan that the battery cables are too stiff and put too much stress on the switch. Perhaps Perko brand switches wouldn't fail as easy as the Blue Seas System switches, but more flexible battery cables would most likely solve the problem.
      • lucky7t
        • Mar 2011
        • 1306
        • Oklahoma
        • 2015 SANTE
        Brings back bad memories .
        Happened to me in the middle of the lake . I used my ninja skills and pulled the lower panel down and saw it simply broke to pieces . Nobody would answer the phone to help (friends )
        After an hour I did exactly what you did . Mine was hanging so I found a sandwich bag and our first aid kit bandages to hold the plastic bag over the hot wires .
        What a cluster $&@“
        Agree this should have been addressed especially since they are aware of this issue
        Current Correct Craft Boat
        Correct Craft Boats Owned
        • mcosub
          • Aug 2016
          • 235
          • Orlando
          • 2020 GS22 2017 SANTE 210
          What a cluster $&@“
          happened to my 2017 210 a few months back. The selector switch would spin freely and the battery would not turn on. Luckily I was at my dock behind me house when it happened and I just went to the dealer and got a new switch. 30 min or so and had it swapped out and had no issues since.
          • lucky7t
            • Mar 2011
            • 1306
            • Oklahoma
            • 2015 SANTE
            Found the images of my sandwich bag and medical tape . You can see the switch ripped apart .
            • whitecaps
              • May 2015
              • 125
              • Eads, Tennessee
              • 2017 GS22 1998 Ski Nautique 196
              Same failure as seen in above post. I drilled out holes where screws are that broke the plastic they are screwed into. Put small bolts with nuts
              through it to hold it all back together not a permanent fix as the nuts on my bolts prevent the knob from being able spin, so it's in the both position for now. Should get me through the weekend.
