Help Ballast pump fault 15’ 210
  • Mccam1172
    • Aug 2016
    • 25
    • Algonquin, IL
    • 2015 SAN 210 95 SN “sold” wish i had not
    i need a little guidance,
    my belly ballast pump will run fine when filling no issues , but when i try to drain it i get a fault immediately. Today i ran the pump on the port side wiring to get it to drain and the pump ran fine, so my guess is it is in the wiring someplace between the 2 pin connector and the linc system.
    any ideas how to rewire this?
    anyone have this issue?
    please help
    thank you
  • AdamJBarn
    • Feb 2016
    • 51
    • Fishers, IN
    • 2002 Super Air Nautique 210
    Well your post is vague. Is that fault on the pump? Have your dealer file a claim.
    • Infinity
      • Sep 2017
      • 730
      • Lake Norman - Denver, NC
      • 2014 SV244 w/ ZR409
      Check all your connections to make sure they are not loose or have corrosion. May be as simply as a loose connection, one could also be going bad or been damaged. If its throwing a code/fault....what is it saying and doing? You will have a fuse to pump too, check it. You may also wanna pull the pump apart and make sure it operates freely (remove impeller and run the fill/drain cycle) there also may be debris in there, or impeller that needs replacing
      • Mccam1172
        • Aug 2016
        • 25
        • Algonquin, IL
        Ok a little more info, the belly pump fills fine, no issues no faults. If i try to empty it trips and throws a fault code ( i will get it when on boat next).
        so to get the tank to empty i switched the port connector to the belly pump and ran it and it emptied fine.
        I i have a spare pump and swapped it in to try it and same results.
        My guess is the reversing of the power to empty i have a bad wire . If i read the election. Schematic right the just switch the + side to get pump to fill or drain. Has anyone else had this issue?
        the boat is now out of warranty and i want to attempt to fix it .
