i need a little guidance,
my belly ballast pump will run fine when filling no issues , but when i try to drain it i get a fault immediately. Today i ran the pump on the port side wiring to get it to drain and the pump ran fine, so my guess is it is in the wiring someplace between the 2 pin connector and the linc system.
any ideas how to rewire this?
anyone have this issue?
please help
thank you
please help
thank you
